Why does my phone heats up and the screen goes black
Hello. Hope you guys are keeping up good. Please my lg v10 heats up and the screen goes black when in use, then comes up back when I remove and insert back the battery
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Does it cool off before rebooting? Your device sounds like it’s powering off as a safety measure - your battery may be shorting out and overheating. You might try a new battery.
No recent submersions right?
このアンサーは役に立ちましたか?
It powers on once I insert the battery back and turns it on. Sometimes the screen remains black but turns up normal after a few minutes. The first battery got swollen and I changed it but still the heating and screen blindness still happens
If your battery has bloated, you need to stop using it immediately. Best Buy has a battery disposal service if you have one near you. Replace the battery. If it bloats again, you may have problem with the phone's charging mechanism, and that's beyond my experience to fix.
Either way, your current battery is a fire hazard and you need to stop using it.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 563
