Huawei P20 GPS arrow not working
I have tried google maps, waze and navigate go… but no arrow is showing up only a blue dot. Which is annoying since its a bnew phone.
Waze says “no gps, showing approximate location”
I have the same problem with my p20? Did you find a solution to it?
このアンサーは役に立ちましたか?
my friends on facebook has the same issue they brought it to their nearest service center and huawei replaced its motherboard
After replacing its motherboard did it work?
Yes it did work for his case. Mine was voided of warranty due to the water damaged that my local service center here in PH claims which is really !#^&^$^ me off. I had it repaired including my LCD but for a paid repair not being under the warranty.
They replaced my lcd, sub board, main flex. Will update you once I claimed my unit again.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,318
