メインコンテンツにスキップ
2019年3月に発売。Mac Pro (Early 2009)は、IntelのNehalemアーキテクチャをAppleのプロフェッショナルデスクトップラインに搭載し、2010と2012のCPUアップデートを加えて、インテリアが再設計されたモデルです。
199回答 すべてを表示
logic board or power supply?
i recently had a power surge in my house while my mac pro 2012 tower was on. tower wont power up, but when i plug ac cord back in i get a red light flash and 5v light comes on when i press diagnostic button. is there anyway i can troubleshoot it my self to see whats the problem? i have some technical experience but not an expert
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Most likely the power supply but first try hitting the CUDA reset button. It is located on the logic board between the front of the machine and the fan. Use a pencil eraser to do it.
UPDATE
https://d3nevzfk7ii3be.cloudfront.net/ig...
Look in the upper left hand corner of the board. Go down to the second input socket , then just to the left of that. White button surrounded by silver square.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
is that the same one that lights up when you press it?
さんによる
コメントを追加
I just recently had to replace the logic board on my 4,1 (flashed to 5,1). Tore it down to the minimum specs as per the Apple Tech Guide and as soon as I installed the Processor Tray I was getting a flashing white light on the power.
It was either the PSU, the logic board (backpane), or the Processor Tray. I bought another cheap 4,1 Mac Pro that was running well and started replacing parts just one at a time. Only thing that fixed it was replacing the backpane.
Unfortunately, there was very little I could do to diagnose this besides replacing the pieces one by one.
Thankfully, I can now just order a replacement backpane and then rebuild the “new” Mac Pro and repurpose it or sell it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
About two weeks ago my mac pro tb the same incident happened. The energy in the office decreased during my work. Since then, my computer has been on, but after a while it shuts down and turns on the red light on the logic board. I believe there is no other solution but to change the logic board. In that case, it's better to buy another computer.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
Corey March さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 786
