Any idea how many interlocks are in the Instax Mini 90?
Bought an as-is Instax 90 someone’s child got to.
The battery and most of the contacts cover are missing. I can see there is an interlock lever inside to check for a film pack. There is probably a door closure switch, also.
The double scissors mechanisms feel like just film pack pressure levers…maybe.
Before I spend money & time replacing the battery contact assembly, I want to think about what else is in there…maybe someone here knows….
Thanks
edited 8-6-18
I powered it up on a bench with a current limited DC power supply, holding DMM probes like chopsticks against the battery terminals. The lens extended when turned on but the camera drew a lot of current…after a few repetions (I put masking tape over the ‘film pack present’ interlock switch and also the two ‘scissors’ mechanisms that hold a film pack flat against the back of the camera interior) current dropped significantly and display and modes look normal. Of course (-) indicates 0 exposures left in the non-existent film pack.
So it might work if I bought a battery & film. Duct tape until I can find battery cover parts (e-mailed Fuji).
I am still curious how smart (or dumb) the camera is if the lens were removed…slim chance of it not objecting.
I am leaning toward Dave Rollans’ method of reloading film back sheets into other cameras to expose & returning to pack & Mini to develop (in a changing bag). Not exactly ‘instant’ but easier than hacking other film holding mechanisms onto the ‘90.
Or just use it as intended with duct tape if Fuji won’t play with me…but I like the prospects of a couple older cameras with Instax better now…
I think Elliott & the USF Tampa team might know more, but haven’t figured out contacting them.
thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
