メインコンテンツにスキップ
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
49回答 すべてを表示
slow and choppy picture with toshiba vcr
Toshiba vcr. Picture itself is great. Discs play kind od slow- stops and starts.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Since you are talking about discs, I will assume that you have a combination unit VCR/DVD. If this is the case, basedupon your description, I would say that the unit is having difficulty reading the disc. If the data is not available for a screen update, you will see a picture as you describe.
In order to provide more information, please post the model number of your unit. Also, check the system by using a few different discs and report whether or not the same behavior occurs with all discs.
Dan
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Toshiba model # SD-V395U. All discs display the same problem, some worse than others. Possible dirty machine ? Laser needing cleaned ?
さんによる
I would start with cleaning the laser lens using a cotton swab and alcohol. Be gentle as the lens is supported by very thin wires. Too much pressure canbreak the wires which will make the assembly inoperative.
さんによる
コメントを追加
回答を追加する
lkg1692 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 104
