Wrong volts placed instead of correct one
I placed my sewing machine wrongly in 220 v instead of 110v now the machine is nt working
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Reena Cyril from teh schematic it looks like the power wire mounts straight to the motor. In that case it is most likely your motor that has burned out. See if you can take a better look at the motor etc. once you partially disassemble your machine. Use this guide Brother XR-40 Stitch Select Knob Replacement to get to it and use this guide to post some images of what you find with your question. That way we can see what you see. iFixitでの質問に画像を追加する方法
ガイド
難易度:
とても簡単
2 - 5 minutes
ガイド
難易度:
中レベル
10 minutes
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 304
