メインコンテンツにスキップ
締切られた回答
Power On/Off Button
Is there a way to know if the power button on my iBook is the problem of if it's something more serious? Computer stopped working and had problems with the power button in the past. Was in the middle of using it when the screen blacked out came back on then went dark again - no power at all now. Have already replaced the power cord so I know that is not the problem. When I push down the power button it doesn't feel like it is going in all of the way. Any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If you follow the guide for this model
you should be able to strip it down to where you can short across the two pins to start. (Step #23 talks about location of the the blue and white power cable.)
Good Luck,
N.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,477
