メインコンテンツにスキップ
An affordable mid range laptop sold by Acer in mid 2015. This laptop comes with a Nvidia 940m graphics card, Intel i5-5200U CPU, and a 1080p display.
29回答 すべてを表示
Are there any ssd compatible whit a acer nitro 5
My computer is a acer nitro 5 its acualy a great computer but when you have alot of games it runs slow and overclocing wont work so if there are any stronger ssds compatible whit the laptop it will be usefull
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
By the looks of the board and what is possible at all, or ever for that computer. If you want a faster ssd you will have to sacrifice Wi-fi connection for as there is only a SATA connection for a maximum for of what 2.5 SSDs can do currently between 500 Mbps to 550 Mbps. This is recommended under Samsung only theirs also have the highest benchmark scores. If you need to install it there is a video online if you search for this pc and upgrades you can do. With that limitation of having no M.2 slots available that is pretty much it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
actually, my acer nitro 5 actually ships with a 256 gb intel m.2 ssd. I don't know if it is the same for all models but for reference my model is Nitro AN515 53. Hope this helps! :)
さんによる
コメントを追加
Actually, my Acer Nitro 5 actually ships with a 256gb intel M.2 SSD. I don't know if it is the same for all models but for reference my model is Nitro AN515 53. Hope this helps! :)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have installed a WD SN700 Black 500gig NVMe M.2 drive, while also installing a SATA 3 SSD 500gig HDD in the HDD spot. works great in my Acer nitro 5 AN515-53.
good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I would settle with getting a 1tb ssd m.2 by WD or Crucial. As for your hdd you could always slap in another 500gb hdd or a 1tb hdd for your game library. I have a 120gb ssd in my laptop and a 1 tb hdd but i might swap the ssd for a 1tb in the near future.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Have you tried installing a 1TB m.2 ssd in the m.2 bay? I think acer said it was limited to 512GB.
さんによる
コメントを追加
回答を追加する
BORKCALIPSA さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 1,482
