cell got wet screen dead
Motorola e4 plus got wet, I was using for around an hour with not problem at all, now screen is dead still ringing but I cant see anything on the screen
marquez3655 just like any other device that does not get cleaned properly. It will fail and shortcicuit. In your case you want to go ahead and disassemble it. Should be pretty much the same way as on here Once disassemble you need to clean it. Use this guide iPhoneの水濡れ・水没ダメージからの復旧方法 to clean it. It was written for an iPhone but the steps are identical for cleaning every device. Once properly cleaned you want to reassemble your phone and change the battery. Always use a new battery with water damaged devices. Then re-evalauate. It is possible that you have an LCD shortcircuit and repalcing that may get your phone back to working condition. Water damage is the hardest to repair since virtually any part may have failed.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 256
