メインコンテンツにスキップ
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301回答 すべてを表示
98 gmc 4.3l v6 oil pan removal
i have all the bolts that i can see from the bottom of the pan, but the pans still hung up i figured it would drop sorta easy with all the bolts out but there must be some i missed. where do i go from here? take the trans out, the whole motor out?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Tap it gently with a small rubber hammer all around the seam. There may be a gasket that's holding it in place. Use a flathead screwdriver on the end to break the seal loose. You can also use the back of your fist and bump it loose.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Careful wit the screwdriver that you do not bend the surface for the gasket, or you will have a leaky pan.
さんによる
コメントを追加
回答を追加する
steven boomer さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 6
今までの合計 1,626
