Washer making strange noise when on spin cycle
Hi all!
My washer is making this weird scary noise during spin cycle.
Anyone know of what I can do? Or should I call a tech?
Thanks!
Hi all!
Thanks!
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka “agitator dogs” (top load washers)
Here’s a comprehensive tutorial on diagnostics and fixes for noise during the spin cycle:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 80
