メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone rebooting loop several months after battery replacement
Hi,
I bought a battery from iFixit several months ago to fit in an iPhone 5s. The battery developed issues and would no longer hold a charge. I contacted iFixit, and they agreed the battery was defective and sent a replacement.
A few more months down the line, I think I'm having the same problem with the replacement battery. When attempting to charge the phone, it will boot to the lock screen before shutting down and booting again. It will only power-on when plugged in.
Could I have two defective iFixit batteries, or is something else happening?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It's possible but certainly unlikely. It is possible your charging circuit is damaging the battery. Are you using an Apple (or MFi certified) charging brick and Lightning cable? If you are using cheap "dollar store" chargers or car chargers, they are known to cause havoc with the charge circuit.
If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it says it's charging.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
James さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 26
