メインコンテンツにスキップ
初代Mac ProはIntel Xeonをベースにしたワークステーションコンピューターです。初代モデルには2006年から2008年のデバイスも含まれます。
Random Mac Pro restart/shutdown
Hi Mayer, I'm having unexpected shut downs on my Mac 3,1 all of a sudden. Started while rendering in Adobe Premiere, now all the time. Did your machines' fans speed up after shut down or is that something overheating. Should I go ahead a try replacing the power supply unit?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Archie, I switched this to your own question so I could give it closer attention.
Please tell me your exact MacPro machine.
My experience has been an escalating frequency of restarts with a failing power supply. Your problem sounds different. First download and run TG Pro and see if you are getting a component overheat.
https://www.tunabellysoftware.com/tgpro/
Also have you ever changed any major components in your machine or upgraded the processors?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Mayer for the quick response. Unfortunately I can’t even run the machine long enough to install TG pro. I tried tonight but it shuts down after a minute or so. It’s a Mac Pro early 2008 3,1 running OS10.9.5. Original cpu’s dual 3.2 ghz quad core. I recently upgraded gpu and ram in attempts to solve the issue. Now running with a GTX 770 graphics card and all new 32gbs Ddr2 ram. No luck, still unexpectedly shuts down even with smc fan control at full blast. Thanks for the help, about ready to throw in the towel.
さんによる
コメントを追加
回答を追加する
Archie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 187
