メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
20回答 すべてを表示
PS4 doesn't start blinks blue
Hey everyone,
I have a PS4 which won't start. All that happens is that the blue light turns on and continuously dims and brightens again. No white light appears, and the PS4 doesn't respond to the controller. I've already tried using a different power supply, but no luck there. I'd greatly appreciate any help.
Thanks in advance,
Minas
This is a different PS4 to the one mentioned in my other thread.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
5件の回答
ベストアンサー
After quite some time searching I’ve come to the conclusion that it is probably a problem with the APU chip. The next step now will be to take a look at reflowing the motherboard, but I highly doubt it will work permenantly.
Anyway, thanks for all the help!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What???? How do you do that mine won't power on at all it had the issue of having to reset it by unplugging and replacing the cable and it would work but this time all that happens is the blue light flashes then it becomes unresponsive. No light what so ever. I took the plastic off amd cleaned all the dust but didn't do and good think it could be the power supply?
さんによる
コメントを追加
最も参考になった回答
there are a few things it could be the the apu chip, ram or southbridge chip. but theres no way to test which 1 it is
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
go on Xbox should fix the issue.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
here's a link i found that may help further diagnose it. I hope it helps.
https://www.usgamer.net
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Since I've tried with different TV's, Power Supplies and Hard drives, I can guess it's only an internal issue. :/
さんによる
I will check and see if I can find a solution other than contacting Sony.
さんによる
Any luck yet?
さんによる
I apologize, I think you are correct in your determination of the APU chip. It requires microsoldering and could be difficult to repair. I wouldn't use the heat gun method as this is likely to do more damage than fix the issue.
I would check with Louis Rossman to see if they are able to change this for you.
https://www.rossmanngroup.com/
さんによる
コメントを追加
Hi
I had this problem too, it took ages but eventually I found an easy fix!
Follow the linked guide and never have problems with your console again
Your welcome in advance
https://bit.ly/2xJ2kC8
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I tried this repair and couldn't get my PS4 repaired. Though I did fix my gaming problem.
さんによる
コメントを追加
回答を追加する
Minas Mayth さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 25,301
