メインコンテンツにスキップ
Repair guides and support for motorcycles manufactured by the German motor group, BMW.
17回答 すべてを表示
Why will my K 1200S not start after Start Supression?
I am wondering if anyone can help me with this issue. If I accidentally attempt to start the bike in gear, the start suppression will prevent this from happening. However if I then take it out of gear and attempt to start it normally, it won’t start. It sounds like the battery is flat. It has enough ergs to just crank the engine over but not enough to start. I have had to wait sometimes up to 15 minutes before I can start the bike again.
After 15 minutes or so, everything seems to return to normal and it will start just fine.
The battery is just the same as it was when it sounded like the battery was flat but now it cranks the engine over just fine.
Any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Ur battery is low or u need to change the fuse
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Ok thanks. Which fuse would need changing? I suspect you could be right about the battery though too.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ralph さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 117
