メインコンテンツにスキップ
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
The controller and the drone unit will not connect?
Batteries are charged on drone and remote batteries are new. Had a problem with a wire coming loose from the pc board that connected a motor. I repaired that and checked the motor before closing up the unit. Drone functioned perfectly. I closed up the unit and now the controller and the drone will not connect. I have followed the suggested procedure for connecting the unit before flight and still nothing. This is a sharper image dx-2 stunt drone Any idea what could be wrong?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
14 件のコメント
I have no clue how to use this site and cant seen to find answers. I have a no connect problen with same dx2. Can anyone help
さんによる
Same problem here.
さんによる
and here... same problem dx 2 remote will not pair ... just flashes
さんによる
Same here I bought my son the dro 004 any ideas
さんによる
Completely charge both,turn kn dx2 then switch your remote on move the left analog stick from down, up, and then back down it should beep then the lights will stay steady
さんによる
9件以上のコメントを表示
コメントを追加
13件の回答
最も参考になった回答
Did u by chamce accidentally knock the antenna from its connection to the pcs wben u closed it back up? Im not sure brother, but this is the first thing coming to mind after seeing u fixed the prop disconnection issue (oddly enough, my wife bought me a dx-2 and I had a motor wire snapped in half by sharper image attatching the top and bottom casing together and catching it/cutting it in half) u in eastern kentucky by chance? Lol. Cauze i returned it to walmart when my splicing job didnt hold well during
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I am in central ky. ( Berea ) have not repaired anything on the drone, took it up for a test flight turned it off and recharged it, and now the remote will not pair it just flashes... any thoughts... ???
さんによる
This is the exact same thing that we did! We used it, it was fine, then we charged it, shut both things off.. and just went to use it and it won’t pair! How annoying! My brother is a mechanical engineer and he’s opening it up right now to see what’s wrong!
さんによる
Mine is doing the same thing wtf
さんによる
Had a previous drone, flew away, bought a new one and now it won't pair
さんによる
コメントを追加
My 2 cents….
Somehow, it's possible the crystal on your fc when batty… don't ask how, why or whatever…. Change the crystal on fc. That should hopefully fix your pairing problem.
But! Make sure you replace it with the same value crystal.
Anytime I've gotten some stupid idea to drop $20 on a toy quad, it never fails… I always end having to replace crystal with new. Smh.
Helpful friendly advise…
Save up just a little more money… get you an entry-level name brand RTF kit for like nada to really get you in the right direction.
From there… the sky is literally the limit.
Good luck.
Have fun!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Its 2.4 gig and does not have replaceable crystal.
さんによる
コメントを追加
I have charged the drone. But the remote control will not fly it. Meaning… the red button won’t pop up when I switch it to on and when I try to use it…it will not fly..,any suggestions ?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Do you mean the red light? On the remote or quad? If one or both wont light the batterys dead in remote or not charged in drone. If batteries are good then problem could be internal damage.
さんによる
コメントを追加
Hi, I was having the same problem with my dx-2 I took a part the remote and everything was fine, but still with the problem of not connection, but did like a external push ( hit the each blade with your finger to make it rotate)to the dx2 blade when still on with the controller on also,and it work my dx2 is flaying again.
Remember hit as you hit a marble but softly and trying the controller to mait flaying .
P.S. recharge the drone to get a full battery power.
Good lock
Androi48.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What do i do, my dx-2 drone is on the “on” mode and its not turning on but the remote is on what do i do?
さんによる
コメントを追加
Can i fly my DX-2 drone without a controler. Can i just use my andiod phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
In order to fly the drones, all you need to do is simply download the android mobile phone app and sync it with the drone and you are set. ... The best thing about this particular drone is that it can be easily controlled by either the android app or the remote controller, which makes it a flexible choice.
Try 360 flight app in android play store
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
the other 2 wouldn’t fly and the others could it’s not flying
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No all Android smartphone wotk with using your phone as remote controller.
Some of this drones work with Bluetooth signal others with wifi.
If you have an android phone or iPhone make sure the your phone model work with the type of drone you have.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have the same problem, all like you new sound controller battery and the drone and fully charged. Except me, when I start the drone and the controller, both start, but the lights of the drone as well as the controllers start to flash and do not connect. What should I do?
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I don’t Know but try rebooting it and if not, try taking it to I.T or go to a nearby company that has drones. Otherwise, that’s all I have for you.
Update (02/10/2021)
Yeah so thats all. I have nothing else for you sorry.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
So if this helps anyone with their problems of the drone no connecting turn both the controls and the drone and click the stun button like 5 to 10 times fast and it should pair the drone that’s what I did with mine and it worked hopefully it works for anyone looking for answers!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
because the energy is not to powerful that mean the drone c ant connect easily
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I can't get it fly why is that
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ben Taylor さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 49
過去 30 日: 201
今までの合計 26,160
