メインコンテンツにスキップ
家庭用から車のオーディオシステム、計算機など幅広いエレクトロニクスギアの修理ガイド
26451回答 すべてを表示
Why is my power wire to my amp not carrying power?
I just finished hooking up my amp and sub. Everything is correct. I have double and triple checked it all. At the battery terminal, the power wire has power. On both sides of the fuse, the wire has power. However, when I go to my amp (I even cut the wire open at the end to check), there is no power to the wire on the amp or inside the wiring jacket. Suggestions?
I really don't know anything about electronics, so if this is dumb, sorry.
Sidenote: I also don't have power to ground or remote (that's not what I'm worried about tho. I should still get power through a wire from the fuse to the back.)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
There is not enough information to properly respond to this question. For clarity, please post some pictures that can show what you are trying to describe. We should then be able to advise properly.
Thanks,
Dan
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi @lil_chef ,
What are you connecting the voltmeter (or test lamp) to at the amp besides the power wire?
If you are connecting it to the amp and the amp is not earthed you won't get a reading on the meter.
If you are connecting the meter(or lamp) to the end of the power wire and chassis earth somewhere in the vehicle then first verify that you have a good earth connection to the meter and if still no reading the wire is broken between the fuse and the end of the wire. Did you run it in or is it an existing wire that may be routed via the ignition switch etc, or something?
(I assume that you are installing an amp in a vehicle - you didn't give much info on this e.g. make and model of head unit, amp , vehicle etc)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Caleb Hagen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 314
