メインコンテンツにスキップ
MacBookファミリーは2006年5月に登場しました。Appleの人気ラップトップであったiBookから引き継がれました。
3786回答 すべてを表示
Certain Keys not Working on Keyboard
Hey everyone, I have a Macbook v. 3,1, and I'm experiencing a strange error. The 1,Q,A,Z, delete, and spacebar keys on my keyboard all stopped working simultaneously, and randomly, a number will get "stuck" without me pressing it, filling whatever text box is active with a stream of 9's or 6's.
If you have any idea what's going on, please help. Thanks so much in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Did you find an answer or a solution? My wife's late-2008 white macbook has exactly the same problem (I believe even the same keys are not working).
さんによる
did you manage to fix your computer? - I am having exactly the same problem !
さんによる
コメントを追加
2件の回答
ベストアンサー
First thought--has anything been spilled on the keyboard? Second thought--I notice the dead keys are in one row so you could have a problem with the keyboard cable. You would need to open the unit a check the cable for damage and proper insertion into its logic board connector. No go on the first two you probably need a new keyboard. Hope this helps. Ralph
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
+ Also try reseating the keyboard to logic board cable and inspect the slot for debris.
さんによる
Nothing spilled on it. It just randomly failed this morning. I'll try opening the case to see what's going on. Thanks very much Ralph.
さんによる
== Check under the keys == for damaged, or malformed scissors or crumbs.
Good Luck,
N.
さんによる
If your question is answered please return and mark it.
さんによる
コメントを追加
im-having-the-same-issue-i-dropped-it-on-the-carpet-from-less-than-six-inches-above-it-but-the-shock-i-believe-may-have-separated-the-connector-i-got-function-back-in-a-few-keys-but-the-f-row-doesnt-work-nor-do-the-modifier-keys.....
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i-am-taking-it-to-get-serviced-i-hope-i-dont-need-a-new-keyboard-i-am-running-osxserria--or-whatever-they-call-it. I started using an external keyboard and it is working wonderfully... I am sure it is the connector cable because the power button doesn't work either I have a mid 2010, unibody macbook... I am having trouble actually finding guides on this site for it :/ despite the relative ease it seems to access the internals :>
さんによる
コメントを追加
回答を追加する
Dame さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 8,462
