メインコンテンツにスキップ
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
How do I bypass stuck key code?
My post keeps saying it’s deleted....?
PLEASE HELP! I have a Kenmore washer Model # 110.21102012. I have a lid lock light that keeps blinking.... Googled issues... did a diagnostic test on it and keep getting F2E1 code back... means Stuck Key. How do I fix it or bypass it?
Things I’ve already done: Replaced lid lock mechanism. Check main control board for damage. Nothing has worked. Washer runs and fills with water for approximately 10-15 seconds then stops and lid lock light blinks with a clicking noise. When I tried to do a calibration it runs for about 15 seconds of it and shuts off.
Please help. Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
If the board does not reset by unplugging it for five minutes, then you can try to take a hairdryer and run the heat back and forth over the user control panel and see if the key will unstick if not you will need to replace the user interface board.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
When using the hair dryer, how can you tell what key is stuck?
さんによる
コメントを追加
Just run it back an forth over all of them
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ronica さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,344
