メインコンテンツにスキップ
car starts off slow and good after. code P0962 . replace how?
I have a 2003 honda accord coupe, no leaks in the transmission at all. When I start to drive the car it takes a lot to get going but after if moves just fine. No problem in shifting and the reverse is good too. Is it the pressure control solenoid valve?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Dexter Murphy, error code P0962=Pressure Control Solenoid A Control Circuit Low. Had the same happening on my jeep and required me to replace the Solenoid. There is a great flow chart fault finder on here I know it does say civic but the error is the same :-)I also attached an image for the transmission and the solenoid is shown as #4 and sits on the outside of your transmission. Good Luck and I hope you get it done.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks oldturkey03 for all your help. I get the part in tomorrow. I pray this is it. Have a great day
さんによる
thank you for accepting my answer and I hope that you get your error code resolved with the new part. BTW my jeep had the same error code and would not shift gears and drove horrible, after changing a $40 solenoid inside the tranny, drives like new. So we'll keep our fingers crossed...Good Luck
さんによる
コメントを追加
回答を追加する
Dexter Murphy さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 42
今までの合計 8,737
