Laptop is messed up
What to do if charger port is messed up and lifting up the screen makes the keyboard lift up.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
mr_mrs031710 for the charging port you would need to repalce the compelte power jack connector with something like this
This “lifting up the screen makes the keyboard lift up “ sounds like a bad hinge. We would need to see more of the hinges. Take some good pictures and post those with your question. thyat way we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that. This video ill help you with the power jack., and this one for the rest of the disassembly.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 149
