メインコンテンツにスキップ
Repair guides and support for a wide range of welding machines.
15回答 すべてを表示
Plasma cutting depth and thickness
I'm trying to open a old safe I found in a building that my company was raring down and its older safe over 350 pounds I've got a plasma cutter 60 amp it says it cuts 1 inch steel as so manybinch a hour
My question is that and will a plasma cutter cut deeper and deeper but it will make the cut slower and very ugly?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I have heard of some older safes containing materials that you don’t want to mess with if you are a novice. I would consult with my local locksmith who I know to be an expert on older safes. Can’t answer your questions regarding plasma cutting equipment however. Movies tend to make stuff look much easier than it in fact is.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
stephen kealey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 127
