メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
327回答 すべてを表示
Broke "sticker" in the butterfly keyboard while cleaning. What is it?
The J key stopped working on my MacBook pro as it did many times in the past. I initially set the MacBook on its side and sprayed the keyboard with compressed air. No dice.
I took off the keycap by inserting a bit of plastic at the top and being careful not to break it. I once again set the MacBook on its side and started spraying air.
I probably got a bit too eager with it, because this little bit of what looks like a black sticker came flying off.
I picked up the sticker and haphazardly put it back where it was. The key still skips a few beats, but it works better than before. However I'd like to understand whether I should be worried about this broken bit.
The J key with the (black) broken sticker at the top
Comparison with a "healthy" G key (compare the left and right corners of the sticker)
What is this thing? Is it critical to the function of the keyboard?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I ran i ti the same issue and with the help if these glue dots right from target and an exacto knife has done the job!!
Scotch Create adhesive dots clear ultra thin (permanent) had a picture of a porcelain fox with polka dots on the front
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
gothic keypunch さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 852
