メインコンテンツにスキップ
Hybrid notebook/tablet released in December 2015. Manufactured by Acer, the Chromebook R11 is an inexpensive option among an already-cheap line of notebooks.
18回答 すべてを表示
How do I repair my touch screen?
I dropped my acer r11 chromebook and now my touch screen does not work.
How do I repair it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
5 件のコメント
a couple of days a go my laptop screen stoped working help
さんによる
Yesterday I logged on to my Acer R11 to do something and the touchscreen wouldn't function properly it still registered but it wouldn't work right, it was dropped 5 days ago but still worked fine afterward so I don't think that had anything to do with it, and it is not even 2 weeks old, I hope I don't have to replace it.
さんによる
I dropped mine during class and grabbed it right away. I found that I could not use the touchscreen but I could still use the stylus and the keyboard. And now while seeing how to fix it I somehow disabled the touchpad. This is the Chromebook pro by samsung.
さんによる
how did you fix it?
さんによる
my acer chromebook r 11 fall touch screen not work
さんによる
コメントを追加
8件の回答
最も参考になった回答
You can try disassembling the laptop and check if the connection between the motherboard and touchpad is loose. It is possible that the connection got loose because of the bump/hit. Else, the touchpad maybe damaged, and in this case, you need to contact a repair technician.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Where is the motherboard once you dissassemble it?
さんによる
コメントを追加
this is a replacement Digitizer.
https://www.laptopscreen.com/English/mod...
This is unfortunately a video of the Acer Aspire R11, hinge replacement, so some screws may be different, but the concept is the same. so the skillsets are transferrable.
https://www.youtube.com/watch?v=nzAmaOuc...
Be sure to keep the adhesive as warm as you can to allow for easier removal.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
maby go to a laptop fixer place or reset the laptop
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It is likely a hardware fault.
Check if the connection between the motherboard and touchpad is loose.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If there is no break or burning in the screen, you can relax in the screen clips. You should open the device and put the dog in its proper place. If you can not do this, you should go to the mobile maintenance mechanic
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
this is a hardware breakdown issue. I would say to bring it in to an expert.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If your a personal user and not a student I would look for the repair guide or take apart the device and get the serial number or part number of the device. Look it up and order the part. When repairing make sure the battery is unplugged this is extremely important. If your not comfortable I would take the device to a repair technician. Screens are really the easiest thing to fix.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
At previous days my laptop touch is not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dennis Bolestridge さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 30
今までの合計 4,106
