メインコンテンツにスキップ
Appleの2世代目のiPad AirでWi-Fiモデルのみを対象をしています。モデル番号はA1566です。
214回答 すべてを表示
Bad charging and Error 4013
Hello :-)
I have an very weird issue on a customers iPad Air 2 Wifi Version.
First of all its not booting, not even the Apple Logo appears.
Second thing is that when I plug it in for charging on my MacBook, nothing happens as well, the screen remains black.
When I plug it in to the 12W iPad Charger, after some minutes on charging, it tries to boot, but the iTunes symbol appears and tells me to restore the device.
When I try so, Error 4013 appears.
Of course I've tried it in DFU Mode ;)
Some research on this lead to a defective NAND chip, but im curious if not maybe the battery could be the issue..
Before I send the device to a technician who's able to swap the NAND chip, I would like to know if somebody here had the same issue and probably a solution that does not require any kind of microsoldering.
Would be happy for any kind of tip.
Thanks and have a wonderful day people :-)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
honestly i would try changing the battery before anything it sounds like it is not getting enough juice . i would also contact apple and see if they can run a diagnostics on it.
iPad Air 2 Batteryの画像
製品
iPad Air 2 Battery
$54.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jimmy industries さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 621
