The white piece in the motor seems to be damaged.
The white piece on my stick blender seems to be damaged. Is it worth fixing?
Looks like this question is from 2018 so this may be of no help now, but I designed it and 3D printed it just now because no amount of searching yielded the option to purchase the part. If you have access to a 3D printer, here’s the STL:
このアンサーは役に立ちましたか?
seria muy util que la empresa fabrique esta pieza con material mas durable.
Hey Dave, that is great, but I don't have access to a 3D printer, could you be able to print and sell me a couple of pieces?
Can I buy this part?
I too would love to be able to buy this part.
The white piece on my Cuisinart Stick Blender seems to be damaged. Is it worth fixing?
このアンサーは役に立ちましたか?
The prompt says to accept answer, but I have received no answer.
la parte central cilindrica blanca, que no es de metal se daño, por picar una cebolla y ahora tengo todo sin utiliarlo, como puedo canbiarlo?
espero tener la respuesta posiblemente tendre que mandar a construir si no hay lla posibilidad de adquirirlo
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 729
1件のコメント
como puedo ramplazar la parte cilindrica blanca no metalica central ?
oviedogallegos さんによる
