メインコンテンツにスキップ
This versatile wireless broadband router released by Verizon in 2006 supports Ethernet and Wi-Fi networks.
Firmware update broke my router?
I tried updating the firmware and the firmware. After it was done, the power light and WAN light will light up, but after the power light turns green it blinks for a few seconds before the router restarts. Is there a way to fix this, or is it completely broken?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Nova Wolf was there a problem with the router before you updated the firmware? if so what was the issue . If not why did you update it. Did you reset the router after doing the firmware update? This troubleshooting wiki may help
Verizon M1424WR Troubleshooting
It kinda sounds like a factory reset is in order. Use the reset button on the back of the router and in doing so you will need to reset passwords and user names
Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I’m not familiar with this router but if there is a way to reset it try that. There usually is a way.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nova Wolf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 229
