Where is the horn relay
Where is the horn relay located on my 1992 Chevy s10 pickup
この質問は役に立ちましたか?
この質問は役に立ちましたか?
terance logan it’s is in the fuse panel beneath your steering wheel. Remove the interior panel under the steering column and to the left you will see a relay, alarm module and flasher. The horn relay is the square one on the lower left.
このアンサーは役に立ちましたか?
Thank you this was very helpful, Felipe!
If you clicked upon this looking for a Sonoma it is under the panel where the release brake pull is take that panel off then it’ll be in a hole with a black box fuse and a circle fuse I don’t know if the other people that answered this was telling the truth but if they are then gmc and Chevy are in different places I have a 92 Sonoma and mines under that panel
このアンサーは役に立ちましたか?
過去 24時間: 11
過去 7 日: 49
過去 30 日: 202
今までの合計 7,706
