battery has stopped working all together
after installing a new m.2 SSD the batter no longer work I am able to boot when plugged in but am I unplug it will middle shut down
Make sure your laptop is turned off.
Reset your battery on the bottom of the laptop in a tiny pinhole (not the screw holes) with something small enough like a SIM card eject tool, if you can’t find it, it might be hidden behind a sticker.
I had the same problem when upgrading my RAM, tech guy was kind enough to tell the solution.
このアンサーは役に立ちましたか?
worked also on my Acer Aspire VN7-571
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 947
