メインコンテンツにスキップ
The Samsung UN55KS9000F 55-inch 4K SUHD TV is a flat panel 2160P TV. Released from Samsung in 2016. Model number: UN55KS9000FXZA.
White rings on tv screen
My tv is 2 years old, white rings have started to appear on the screen, 5 at present and looks like at least 3 more are starting. is there anything I can do, Samsung say it is out of warranty and do not want to know
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
16 件のコメント
It is a series 6, 50 inch, 4k tv. I thought it would last for years being the latest model, not just 2, very disappointed with Samsung
さんによる
Samsung should offer compensation!!!
さんによる
Same happened with our Samsung. 2 years,and looking for the nearest dumpster... Very disappointed with Samsung. Will NEVER buy anything from them again
さんによる
am the very same got to buy another TV,I had always bought Samsung but thinking different now .
さんによる
I've had my 40" 4k just over 2 years and yes I have a the same light ghost white all the round near edge of screen slowly getting worse. I have a 5year something from Richer Sound. Will be contacting them soon .
さんによる
11件以上のコメントを表示
コメントを追加
9件の回答
最も参考になった回答
iangardiner  without seeing what you are seing and going by your description alone, it sounds like the caps (as in real caps that cover the LED’s not caps as in capacitors) are falling of your backlight LED’s. Post some pictures of what your display is showing to verify that. Use this guide iFixitでの質問に画像を追加する方法 for that. Also verify your TV’s exact model number.
If so then you will have to totally disassemble your TV/Panel to get to the backlight array. The caps can most often be glued back in place. Not a terribly complicate job just very tedious.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
iangardiner to repair this would most likely cost you nothing but your time and possibly some glue. For someone else to do it could be expensive since it is tedious and will take time.
さんによる
I still say that this is unusual. Iangardiner, where are you located? This is a job that should cost less than $200 including any parts required.
さんによる
I am in Manchester, in the UK
さんによる
I have re-glued the lens covers over the LED's to fix that problem. it not complicated just make sure they are oriented the same as the others. It is a common problem, there are many videos on the web that show the process.
さんによる
A have two white dots on mine how much will it cost to get it fixed
さんによる
1以上のコメントを表示
コメントを追加
All answers are correct, but let try to clearify. There are rows of LED (light emitting diode) lights that emit the light for the screen, and on top of those are glued the reflectors, which broadcasts the light created by the LEDs. There is a white defuser panel that covers the reflectors, which evenly defuses, the light created by the LEDs. The LCD (liquid crystal display) sets on top of the white duffuser panel where the light passes through the LCD creating the picture for the screen. When the reflectors fall off the LED lights, the bright light from the LEDs appear as a white rings or spots on the screen. You have two options if the screen is not under warranty, pay to have it repaired, or do it youself. There are videos on the internet that show you how to do the repair, but keep in mind if doing it yourself, it can be a very tedious, and delicate process, especially with larger screens. It is not always as easy as it appears in the videos; one little mistake, and your out of a tv!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I replaced the LED’s in a friends TV and after he got it, it had the white circles. None of the lens had come off, but I did notice there the lens had glue from the tape on them, once I cleaned them all off with IPA the white circles went away.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Can you post a picture of these "rings" please?
As far as I know there are no caps behind the panel. There should be LED strips that provide the back light. These LEDs can fail, but when that happens, usually the entire strip or sometimes the entire back light will fail. Depending on how the strips are powered, the LEDs on the strip are connected in series which means that if one fails, the entire strip will be effected. Some sets power each strip while others have all strips in series. From your description, it sounds like one LED (or 5 if there are 5 "rings") is brighter than the rest. This may indicate an LED that is starting to fail.
A picture will help. In any case, either replacing the strip or the individual LED may resolve the problem.
Dan
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
I will try to get a picture, I don`t have a camera. or use a mobile. The first rings started at the left hand side of the screen the second just below it.the third is top centre of the screen, no4 is just to the right of no2, a couple more are forming just below the group of 3. If it is the led`s failing, is it something I could try and fix myself and what would it cost? how much would an engineer charge or should I just buy a new tv
さんによる
Unfortunately, trying to diagnose this remotely is tricky at best. See if you can get a picture of the problem. That will be the most helpful in trying to resolve this.
Dan
さんによる
caps as in caps to cover the LED not caps as in slang for capacitors 8-). The caps on top of the LED's on the backlight strips fall off and create white round spots ......
さんによる
That makes more sense and yes that would cause what appear to be rings on the screen. Thanks for the clarification. I have to admit having repaired 100s of sets, I have never seen an LED lens (cap) fall off before.
Dan
さんによる
You are the expert on this not me. I am just an old dude who fixes stuff for free as a hobby and community service. I do believe in the mission of iFixit and ewaste and try to keep things working. Just finished 2 (LG and Samsung) within the last month with exactly those issues.
さんによる
1以上のコメントを表示
コメントを追加
The led light reflector at the back of the led panel has dropped off. Need to call tech to disassemble the panel and to fix it back which normally by using glue
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
What kind of glue should be used
さんによる
I used Apoxy on mine. Everything I read says do not use super glue as it is not heat resistant
さんによる
コメントを追加
You have to remove the back plate and lift the screen. There’s a white backer that covers the led array. On each led there is a diffuser cap. Sounds like the glue on yours failed on one or multiple caps. While in there wiggle any of the other caps so that if the glue failed on any of them you can address it all at once. Get some glue like either gorilla glue or super clue and glue the diffuser caps back down over the diodes. This is a known issue with Samsung tvs. https://m.youtube.com/watch?v=Tv5s0KttNX...
this link shows how it’s done.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Why not a class action suit because it is wide spread and a “common issue”.
さんによる
コメントを追加
The lens coming lose or off because of the heat of the leds and how old the tv is after 2 or 3 years you have to replace all leds strips.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Happened to me it is a manufacturer fault the lenses behind the screen are stuck on with inferior glue but Samsung don’t want to know they should be held to account they can be reglued with proper glue if you ring around tv repair shops they will quote you a price it happened to me 18 months ago and I did get a quote for £100 but I can’t remember who with
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well i am broke as a joke so either. I get a new tv or deal with it till it breaks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Is it a samsung? Because i had the same problem they said its the small lights behind the screen and if its out of warranty its not worth getting fixed
さんによる
コメントを追加
回答を追加する
iangardiner さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 34
過去 30 日: 206
今までの合計 56,846
