How do I change the belt for the brush head on a Dyson DC28 Vacuum
The vacuum works but the brush head does not turn. Also, the buttons to control the brush height do not work either.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
i have a dyson animal.. the older version of this vacuum.... when you turn it over there should be several "screws" that you undo with a coin, this will remove the cover over the brush heads. Ours frequently gets clogged with long strands of hair and string etc, this may be stopping the brush from turning. take a look at this http://www.dyson.com/support/help.asp?ar...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 37
今までの合計 9,670
1件のコメント
the motor head is not working,
brush is not moving
Lidia Laudecina さんによる
