メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
Why does my charge port randomly stop working?
This has been a recurring issue for about two weeks with my iPhone 8. It happened about three or four times.
The first time, I noticed my headphones weren't working properly. Then when I tried charging it, it would not charge. I reset all the settings on my phone, but that did not work. But when I finally did a hard reset on the phone, it started charging again.
The second time, there was a piece of pocket lint in my charge port, so after taking that out it started working again.
The third time, there was pocket lint in my charge port again. After removal, the charger still didn't work. I did a hard reset several times, but it still didn't work. Finally, the phone died and immediately after it died, I plugged it back in and the phone started to recognized that it was plugged in and started charging again. After a few minutes, it powered back on and started to recognize the charge port connections again.
Is there a permanent fix to this issue? Or do I just have a serious pocket lint problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Replace the dock connector! And no pocket lint is normal but it shouldn't happen all the time! I'd throw your phone in a lifeproof case
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
At the first, pocket lint is easy to solve, you can find many type of case have dustproof fution.
Peplace the dock connector, but it is no easy job, iphone 8 is water proof, so if you replace it, you need to replace the lcd adhesive, anyway, after you open your phone, then waterproof is no good as new.
If you need the products, you can check here, iphone 8 dock connector, lcd adhesive
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brandon Correa さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 676
