I forgot my password
i forgot the password for my iphone 8GB
この質問は役に立ちましたか?
If you are locked out you can contact the sim carrier for a PUK code. You can also do a restore with iTunes/dfu but this may erase your phone content
このアンサーは役に立ちましたか?
If you encrypt an iPhone backup on iTunes and then forget your password, you will not be able to restore from backup and your data will be unrecoverable. If you forget the password, you can continue to back up and use the device, however you will not be able to restore the encrypted backup to any device without the password. You do not need to enter the password for your backup each time you backup or sync.
If you cannot remember the password and want to start again, you can use a SmartKey iTunes Backup Password Recovery for iPhone to unlock iPhone backup password at first. Check out http://t.co/IWoxSSzVBO for more details.
このアンサーは役に立ちましたか?
You will have to restore in DFU Mode:
instructions can be found here: How to unlock a disabled iPod?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 7,070
