メインコンテンツにスキップ
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
54回答 すべてを表示
What screwdrivers do I need to disassemble the xps 15 9560?
What screwdrivers do I need to disassemble the xps 15 9560? I need to change the HDD to a SSD.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
選択されたソリューション
Needed screwdrivers:
-Phillips screwdriver #0
-Phillips screwdriver #1
-Torx #5 (T5) screwdriver
https://topics-cdn.dell.com/pdf/xps-15-9...
The IFixit toolkit is very much an overkill, but I might get it so that I'll have all future screws needed. (And hopefully it is of a better quality than their less pricey competitors)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
The majority of Dell laptops use #0 or #00, depending on the system, and screw location. For the SSD it's usually #00 whole the other screws tend to be #0 due to the nature of the M.2 screws making this unavoidable.
However Dell is known to secure the XPS machines externally with T5 or T6 Torx screws but that's where the Torx shenanigans end. They've done it for a while on these XPS laptops.
My recommendation for a laptop like this is to get the 64-bit driver kit so you aren't stuck if my educated guess is wrong.
Mako Driver Kit - 64 Precision Bitsの画像
製品
$39.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Alessandro さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 33
過去 30 日: 140
今までの合計 21,607
