メインコンテンツにスキップ
HPプリンターの修理ならびに解体ガイド
1090回答 すべてを表示
Error says paper jam, but there is not. What could cause this?
I have an HP PRINTER all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps it told me to take 3 times. There is no paper jammed anywhere! Each time I finish the steps and turn it back on, it makes a grinding sound, then I get the same paper jam error message. I need some helpful advice if anyone has seen this before, please tell me what I should do.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The sound when you start the printer probably is not related with the paper jam.
The reasons for this error can be different every time.
Clean some of the gears inside the printer. After some years they just need cleaning .
Some times there is an issue with a small elecromagnet inside the printer that is used to track the paper inside . For this step you might need to give the printer for repair. It still worth the money.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bethanyq Brookes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 8
今までの合計 50
