Washer not working/just hums
My Kenmore 11020902991 fills then does nothing/hums
Carbon brushes in the motor: If you switch on the machine and it makes a humming sound as though it is working but the drum does not turn, then the most common explanation is worn out carbon brushes in the motor. ... Washing machine pump: The gentle humming noise may be caused by a jammed pump trying to turn.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 3,607
