メインコンテンツにスキップ
iPad mini4のWi-Fi対応バージョンの修理ガイドです。モデル番号はA1538。2015年9月9日に発表されました。iPad mini4はiPad mini3の後続モデルです。
Can someone identify this component
Hi can anyone help identify the component which should be located in this photo circled in red , it was missing and the small component next to it was off its pads looks like pry damage to me .
It is near the short connector which go's to the display.
zxw tools doesn't seem to be much help with this board ..
Board is 820--00180-B .
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hey, were you able to resolve the issue? Was it a bad screen? Was it the Tristar Chip?? I’m having power issues with mine
thanks
さんによる
@travelpro85
Hi , no this one went into the box of spare parts ..
さんによる
コメントを追加
2件の回答
ベストアンサー
I just checked a mini 4 board I have on the bench. This is a 100K / 01005 resistor acting as a pull-down. This is similar to the circuitry on the iPad mini 2 (see R2241 on page 19 of the schematic).
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thats great , thank you , do you also have the correct orientation of the 1610A3 chip , it looks like this has also been replaced , i want to check it is on correctly .
As when i connected the charging cable i had the apple logo briefly then connect to itunes but back to black screen as soon as cable is removed .
it will not connect to itunes on pc either , so im thinking maybe the tristar chip not fitted properly judging by the pry damage .
さんによる
If you look at the logic board length wise, with the WiFi Ic to the right, then the dot on Tristar is at the top-right hand corner.
さんによる
コメントを追加
thanks for your help , just to be certain , this is correct ? .
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Yes, that's good.
さんによる
Hi again , ive replaced the chip , still no joy , could you please check your board to see if there should be a component on the pads to the left of the cap just above the chip in the photo ,
From the limited zxw board view it seems there should be .
さんによる
Very strange symptom when plugged in see video , https://www.youtube.com/watch?v=7lG82F3j...
could this be because the screen is smashed ? . The battery is dead flat too.
さんによる
コメントを追加
回答を追加する
markparnell1972 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 29
今までの合計 1,012
