メインコンテンツにスキップ
A Sony camera in the HX series of the Cyber-shot line.
5回答 すべてを表示
Can I change the language of my camera from Japanese to English?
Its basically that. I have this Sony Cyber-Shot from Japan. The whole system is in Japanese. I cant understand anything. Can I 'translate' it? By firmware or any way? How? Thanks in advanced!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
5 件のコメント
hi, i have the Sony DSC-R1 in Japanese version did anyone succeeded to change it to English ?
I HAVE ALSO TRIED TO CHANGE MY SONY NEX C3 & IT DIDN'T WORK :(
さんによる
Any one knows if it's possible for SONY A7 III??
I can't find any answers.... If you know something, please help me! :(
さんによる
Need help to change RX10 M4 menu from Japaness only to English! Thank you in advance!
さんによる
I succeed to unlock all language on my Sony HX60v, with this program: pmca-gui v.17, yuppyyyyy :)
さんによる
File wouldn't open on my Win 10 pc. After may tries the win gui file opened but when I clicked on the tweaks tab it could not find my Sony camera. I connected and reconnected the camera several times.
さんによる
コメントを追加
8件の回答
選択されたソリューション
https://github.com/ma1co/Sony-PMCA-RE/re...
Install GUI version. After installed and camera is connected to USB go to tweaks and you can allow all languages on Japanese version Cameras.
このアンサーは役に立ちましたか?
スコア 13
29 件のコメント:
This is EXACTLY to correct answer! Thank you very much for taking the time to reply to this and post this answer.
My wife bought this $750 camera in Tokyo and assumed we would be able to switch it to English when she got home. I could not find the English language setting in the menu. She did a search of Japanese websites and they all stated this was a Japanese only version of this camera; it was not the international version. She was very sad to read this.
This application worked perfectly! First click the tweak tab, second, click the Disable Protection check box at the bottom, third click Enable All Languages check box. Done.
Changing to other languages is now enabled in the camera menu. In the camera you still need to be able to read enough Japanese to find the change language to English setting.
さんによる
Very useful, used on my Sony WX350, japanese language only. Small comment: charge the battery first :-). In order to enable all languages, first has to be enabled 5th box (software unlock, I think).
さんによる
The answer posted by Badger on 27 July is exactly the correct answer.
さんによる
This works with dsc-rx100 model?
さんによる
@joao_vitorio i just tried on my dsc-rx100 model, and it works!
さんによる
24件以上のコメントを表示
コメントを追加
Here’s how:
Language Setting
Selects the language to be used in the menu items, warnings and messages.
  1. MENU   (Settings)   (Main Settings)  [Language Setting]  desired mode
  2. http://docs.esupport.sony.com/dvimag/DSC...
  3. UPDATE 6/29//18
The above failing, talk to Sony directly here on chat:
https://esupport.sony.com/US/p/support-c...
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Almost! I can go until 'Main Settings' by following the little pictures icons. From there, I have no idea, since everything is in Japanese writing (kanji). Can you be a little bit more specific? Thank you so much!
さんによる
I discovered with a friend that the only avaliable language is Japanese. Can I change the Firmware? The OS?
さんによる
コメントを追加
Here's the user manual:
https://www.google.com/url?sa=t&rct=j&q=...
From that you should be able to work out how to navigate blind to the language setting.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
さんによる
コメントを追加
https://youtu.be/F_BKXYfPgB8 how to force change language to English solution
just now by majid
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Persistent rumor has it that cameras intended for the domestic market won't have English as an option.
Did you buy this camera in Japan, or online from Japan? If you did, unfortunately there’s no good chance of changing the settings to English. I doubt they would have different settings for the same company though.
Anyway, you can just check out the Sony community for some possible solutions.
We would all love to hear what you know about this. Please report back.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I wanted to buy the ZV-E10 but unfortunately I became aware at the shop that you cant change the language could someone know if running this firmware it could be possible to do so?
Also ive heard that this firmware does not work with all sony cameras
if so someone can recommend me some like this model?
さんによる
I have the same problem
さんによる
コメントを追加
Can we change Japanese language in sony fdr ax700 camcorder? Help me on this.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Can you help to make it working for sony A6100 too?
many thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I went to Best Buy and the guy there said it is locked in Japanese. I think he doesn’t know what he is doing. Can someone help me!
さんによる
コメントを追加
Didn't work for sony rx100vii. You can help-me ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
guilherme.sarmento さん、ありがとうございました!
統計データ:
過去 24時間: 57
過去 7 日: 397
過去 30 日: 1,492
今までの合計 27,678
