メインコンテンツにスキップ
The second generation model's body has a wider track and longer wheelbase than the previous MDX. The engine was upgraded to a 3.7 liter V6 tuned for 300 hp. It accelerates from 0-60 mph in 6.5 seconds, one of the most powerful engines Honda has produced to date.
Sometimes it will crank but no turn over
Sometimes the car won't start
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Could be lots of things:
  • Replace your spark plugs - be sure to get the exact ones specified in your owner's manual, and gap them correctly.
  • Replace your air filter and your fuel filter.
  • Make sure your timing is set correctly.
  • Make sure all of your spark plug wires are securely plugged in on both ends.
  • Put some gas treatment in your gas tank next time you fill the tank. A friend of mine who is a heavy equipment mechanic recommends Seafoam:
https://seafoamsales.com/auto/
Seafoam got my lawn mower running like new.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
One or two , thing I have ran into my self , Fuel injectors & vacuuming water out of the thermostat
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tameko さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 366
