メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Volvo XC90 is a mid-size luxury crossover SUV manufactured by Volvo since 2002 and now is in its second generation.
Volvo XC90 2.5T Will Not Crank, Starter, Relay, Fuses All Good?
All of a sudden with no warning stopped and would not crank, no immobilizer activated, just won't crank, had to have towed home, checked starter, jumping pin 87 to 30 cranked starter, so it is not starter, swapped starter relay, checked all fuses with meter, pulled halo to check connections, pulled apart ignition and sprayed electronic cleaner on contacts and connections, nothing has helped. Any suggestions on how to resolve this mystery.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
8 件のコメント
Greetings everyone,
I hope that this issue is been solved by now. However, for those of you following this thread, I would suggest to check the battery first. Are all the components getting electricity, can you hear the fuel pump running. Just asking, by any chance did you get new key fobs?
Best of luck to you all!
さんによる
Turned out to be transmitter in key, crazy, took a month in Volvo service after having to tow XC90 to dealer, another $250. after having it towed home for $125., then dealer says need new key, had to order from Sweden, another two weeks, and finally, It starts, but with bill of $550. I said the key was more than the XC90 was worth. lol
さんによる
Dear Friend
I have a similar case with a 2018 XC90. The motor turns Y turns but does not start. Everything started since the airbag module was changed for a new one. but even though the original airbag ecu is returned the engine does not start. any suggestions?
thanks for your help
さんによる
When you mention changing the airbag, that seems to imply an accident? There are many things which you have to check if you have not already. First, does the locking of your vehicle set the alarm system, as in, the blinking light activates, then leave window open, open door, see if alarm goes off. Sounds crazy, but this alarm system will cause no start conditions. So verify alarm is working properly first.
Obviously, check all fuses, a blown fuel pump fuse can cause crank no start condition, as will the fuel pump relay. You can look under the hood and fuse box is easy to access on driver side in square plastic box in plain site. Pull cover and you will see lay out chart, look for related fuses for fuel pump, you can swap the relay with other like relay in box. You will see several are the same relay, so easy way to diagnose with no cost or tools needed.
CONTINUED:
FORCED-SUCCESS-SYSTEM.com
さんによる
CONTINUED:
If you have verified you have fuel to engine, then check spark, not as easy, for you need tools to pull a spark plug coil and insert screw driver into the end of coil obviously leaving it connected, place near engine and have someone crank the engine, you should see a spark at the point of grounding screw driver to block of engine, WARNING, do not touch metal of screw driver, hold plastic handle to position near grounded block to see spark. If no spark, that points to other fuses, so check related fuses again. There are also fuses in the drive side dash panel, as well as under steering wheel to left, as well as in rear driver side compartment panel, check them all, there are dozens of fuses which may be your issue.
CONTINUED:
さんによる
3件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
Turned out that the ignition key decided to crap out, would not transmit to ignition halo receiver, had to get towed home, and then to dealer, XC90 sat in dealer for a month before they could diagnose, then said they had to order key from Sweden, another two weeks, crazy, but what was even more crazy, cost me over $550. including tow, all for a stupid new key.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
@forcedsuccess is this nanohydrofusion you as well? :-)
さんによる
Yes, sorry for confusion, had computer crash and as I am on so many forums I couldn't remember if I had registered before, then got an email saying how many were helped, but when I signed in with newest remembered ID, didn't notice it was different user name. Thanks for letting me know.
さんによる
Sad to say, it turned out to be key transceiver which set immobilizer to not crank. Had to have XC90 towed to dealer since it has to be programmed, they didn’t get to even bringing vehicle into service for 5 weeks, then the bad news, they had no key in stock, had to order from Sweden which killed another week, but here is the worst part, $550. for a flipping key and programming. Last Volvo I will ever own. By the way, I replaced starter, starter relay, new battery even though it was only a year old, new receiver halo, ignition switch, so everything but the most expensive issue, the key. Lesson learned, with Volvo’s it is always the most expensive part. lol
さんによる
コメントを追加
Lost communication with vehicle immobilizer control module
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Is this a reply to my question ? Sorry for Mr spelling & punctuation had to drop out of schoolmiddle of 7th grade to help feed mom and brothers nit complain just explain thank you my question is up above I would be in heaven if someone could help me i tucked away every dollar I can with on 6 year old and a tiny 2 bedroom apartment and power and food I was able to tuck $325 away over 6 months i will spend the whole thing if need be thank you guys in advance !!! Sincerely Jeff Platt / soccer mom my questions above thank you in advance ro everyone or anyone that can help im an awsome stick framer carpenter would offer my 21 year experience in home remodel new and old
さんによる
@jeff40936 No, it was not a reply to your question, jeff. It's dated Jan 5, 2023 so unless the poster has a time machine it was in reference to the original question. You will usually have a better chance of getting an answer specific to your own issue if you start a new question rather that hijacking an old thread.
https://www.ifixit.com/Answers/Ask
さんによる
コメントを追加
My key turned out to be the issue when immobilizer issue prevented starting the engine. Can you set alarm successfully? As in, when locked, does your red dash light blink, if you leave window open, then open door to see if alarm goes off. It is a matter of process of elimination before replacing parts unnecessarily. Does you engine crank or not? Just too many issues without knowing more.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My xc90 is becoming a massive problem, what started with my battery easily draining and requiring jumpstart has become what I can only describe as unpredictable, random refusal to even crank, just a dead ignition with a symphony of clicks coming from engine bay, the periods now can be 8 -10 hours before I turn the key and presto, running great, my obd is no help and all the car is giving away is START PREVENTED TRY AGAIN... Im at the point where I can't rely on it so once started, leave it running, no exceptions, which is causing problems in its self... Any ideas
さんによる
コメントを追加
Im having a issue too where its starts from 7am to 12 but from 2pm to like 10pm it wont turn on. So ya think it could be the key also. Everyday same time… im already stressing out
このアンサーは役に立ちましたか?
スコア 0
11 件のコメント:
No, that does not sound like a key issue. It would more likely be heat related, so when you say it won't start from 2 to 10PM, do you mean it won't crank, or turns over and failed to start? Obviously in AM it is cooler in most areas, and heat is an issue in some cases with no start problems.
さんによる
It would be helpful to others to post your problems solution to define what caused you starting issues.
さんによる
Also having this issue...cranks in morning...even at freezing temp. Refuses to crank in afternoon. Replaced battery and starter. Still no go.
さんによる
Got an 05 Volvo xc 70 took out the battery as we were leaving for awhile and realized I couldn’t lock the hatch so put cables under hood and locked all doors and hatch now back home and get message Start Prevented try again so I have tried all the door locking tricks Replaced the antenna ring checked all fuses bought new battery and still the same problem I am A 600 dollar tow job from nearest dealer PLEASE PLEASE HAS ANYONE any other suggestions. thanks in Advance Bandit
さんによる
Did anyone get a resolve for this. Mine is same 12pm won’t start but starts in the morning? 2010 XC90
さんによる
6件以上のコメントを表示
コメントを追加
回答を追加する
M Sullivan さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 24
過去 30 日: 104
今までの合計 17,934
