メインコンテンツにスキップ
2.6GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.2GHz)、3MB共有L3キャッシュ
120回答 すべてを表示
Replaced battery but the Mac is shutting down at around 68-70%
Hi, I replaced the battery in my Macbook Pro (i7 not i5) last Friday and have had problems since. Followed all the instructions about charging up then running battery down. It is now switching off at around 68% capacity when running on battery and is running down from 100% in only a few mins. Below are two coconut readings - 1 at 09:32 running on battery
6 mins after that it switched off. I rebooted then took another coconut reading here
Not sure what to do now. Fan seems to be on so don't think overheating is the issue.
Appreciate any advice.
Barry
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
How much did you pay for the battery? Cheap batteries tend to perform like this. If it wasn't cheap then I would try reseting the SMC. Also maybe try unplugging and plugging back in the battery.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Coconut battery readings and symptoms described point to a faulty replacement battery. In no circumstance a new battery should show such readings. Contact seller enclosing screenshots and ask for a replacement.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Absolutely agree! This appears to be a real cheapy knock off sold on corners from vendors in long trench coats.
さんによる
コメントを追加
回答を追加する
Barry Carson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 97
