メインコンテンツにスキップ
2011年7月21日に発売されたMac Mini Mid 2011モデルはCore i5もしくはCore i7プロセッサ、Thunderboltを搭載しています。
Unable to use secondary drive (Solid State Drive)
Hello, having an issue with my Mac mini. It has a dual drive setup. Previously two hard drives but secondary drive was swapped with a ssd. However for the secondary drive, it will not allow me to mount, erase, first aid or restore the drive. My first assumption was that the hdd was failing until I swapped this secondary hdd with a new ssd (which I know works fine) and the same thing happened (will not allow me to mount, erase, first aid or restore drive). I am thinking the SATA cable to the secondary drive may be faulty. What do yous think??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Very likely!
The ribbon cables are not very forgiving around the folds as well as the connector points. I’ve had to replace a few in the Mac Mini’s. Don’t go crazy with tight folds I also find I often need some double stick tape to help hold things as you can also damage the cable as you slide the case on or off.
I would recommend you replace both as its just less work to do it than having to re-open the system as you did the wrong cable ;-{
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Liam Boyle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 129
