メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
MacBook turns off when charger is unplugged
Hi everybody,
So suddenly tonight my Mac turned off by itself after being unplugged from the charger, even though it says it is 100% charged. Last night this wasn't happening.
I have noticed over the past few months that the full charge lasts less and less, something like 5 hours or so. I usually just have it plugged in all the time. I admit I use it a lot, so it doesn't surprise me battery capacity is going down. But it was only tonight that the 'Replace Now' message popped out.
I downloaded Coconut and the stats aren't looking good at all, which makes me think it's absolutely time to replace the battery.
I don't mind using it only while plugged in while I replace the battery, but I was wondering if there is any chance it isn't the battery since again, my Mac insists the battery is charged.
I reset the SMC and the issue of it turning off by itself after being unplugged persists. It also may take two or three times of pressing the power button til it turns on.
Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
With the figures Coconut battery shows no wonder you're experiencing weird behavior. Apart from capacity, when a battery is in such a bad state it might not deliver enough power too, that's why Mac doesn't want to start. A replacement would definitely be in order here.
MacBook Pro 13インチ Retina Display Early 2015 のバッテリーの交換
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
jeffydelavega さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 10,079
