メインコンテンツにスキップ
Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
130回答 すべてを表示
I forgot my screen lock pattern and would like to know how to reset it
I replaced the screen on my voyager ii and havent used it in months. Thought maybe i could access it from my android phone but it cant find it. Ho can i reset the lock pattern
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
I FORGOT MY P[ROSCAN PLT7777G-Q PATTERN, PLEASE HELP ME. G.Cyrus
さんによる
コメントを追加
6件の回答
ベストアンサー
#1 Make sure tablet is powered off.
#2 Hold down Volume + button and Power button at same time.
  1. 3 When screen comes on let go of Power button.
  2. 4 When the large Android shows on screen let go of Volume + button.
  3. 5 Use Volume – button to scroll to Wipe Data/ Factory Reset
  4. 6 Tap Power button to select.
  5. 7 Use Volume – button to scroll to Yes.
  6. 8 Tap Power button to select.
  7. 9 Tap Power button to select Reboot System Now.
このアンサーは役に立ちましたか?
スコア 13
10 件のコメント:
Thanks Justin. Just an issue now with a laggy touchscreen. But i'm in. Thx again
さんによる
i for got my password a week ago and this really helped me thx
さんによる
Thanks by little cousin is able to play now my cousin the little cousins mom got from a friend who forgot the pattern lock in 12 am my big cousin is happy thx again
さんによる
Thanks Justin, you are awesome! Now I can swap this tablet for my phone with my grandson! Yayyy!
さんによる
Oh my goodness... THANK YOU!!!!
さんによる
5件以上のコメントを表示
コメントを追加
this solution will reset your device. Which is the only way to unlock it
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks for the reply. Worked like a charm
さんによる
コメントを追加
I still can't get the pattern lock off I've factory data reset the %#*@ thing and re booted t he system and its still locked does anyone have any suggestions please help
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I am having the same issue. Factory reset multiple times and still asks for the pattern to access the tablet. How do we get passed this?
さんによる
I am having the same problem. Please help!! Why want the pattern change??
さんによる
I am having the same issue. I have reset it multiple times and its still locked. Please help
さんによる
Same here. No one seems to know what they're talking about.
さんによる
コメントを追加
Hi the only way to get past the lock screen is to reset the device back to factory in the recovery menu of the device. You should try to power it off then hold the down button and power button this should take you into recovery. From there you should scroll with the volume buttons and wipe/ factory data reset the device then reboot.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
thanx……You made me feel like I knew what I was doing….
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Yes! It worked. Thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dale Reese さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 23
過去 30 日: 147
今までの合計 17,479
