メインコンテンツにスキップ
Repair and disassembly guides for electronic keyboards.
186回答 すべてを表示
Power supply jack needs repair or replacement
Yamaha P-120 S
The power supply jack has become loose, even "jiggles". Is this as easy as replacing the jack, or perhaps soldering whatever is loose? I'd like to know if it's fixable before I tear into it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@mikeghc here is the manual for it. yamaha_p-120_s.pdf. with that you can disassemble your Keyboard. The connector in question is JK101 and the Yamaha part number for that is V8149800
You can try and source the connector either from a broken board (it appears that most Yamaha Keyboards use the same connector) or you can measure the physical attributes and see if you can find a match at either mouser.com or digikey.com as well as any other place. Your keyboard is definitely repairable Let us know what you find.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I was hoping a simple re-solder would do the trick. It's just the jiggling that causes the connection to be lost. Very frustrating, obviously!
さんによる
@estonepiano that sounds like a wore out connector. Of course could just be a bad older joint but you’ll have to check that out.
さんによる
コメントを追加
回答を追加する
Mark Carter さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 46
今までの合計 882
