メインコンテンツにスキップ
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542回答 すべてを表示
The headphone jack does not register my headphones
My PC wont register my headphones but they are plugged in.
This started out as a little thing but it built up into not registering the plug at all. The headphones work with my phone so they do work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
6 件のコメント
Livewire
what computer is it or at least what brand motherboard? Separate sound card or are you using an onboard sound card?
Rep: 1
さんによる
It has an integrated sound card but I'm thinking of getting a USB soundcard.
EDIT: I don't know what type of motherboard and my pc is pirated windows 7 and my rating is 3.5
さんによる
Hi Livewire, can you check on your device manager, under sound , video, audio controller, do you see if the mainboard sound card is detected, like realtek, etc?
how about the rear connection? does it works?
さんによる
It works sometimes but only through one ear
さんによる
it has no audio controller
just high definition audio device
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
without going into too many details or asking too many questions, as a tech the first thing you do is the simple things. so I would check the sound card drivers first. Otherwise it is looking like there could be something physically wrong with the jack itself . After making sure your drivers are good since you know the headphones are good, If you can open up your computer and see is there are loose connections or shorted wires and that sort of things. I apologize for not being able to be more helpful with this one. I really do hope that you resolve your issue without having to spend money
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Livewire さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,365
