メインコンテンツにスキップ
2015 Retina MacBookの最新モデルです。モデル番号はModel A1534, EMC 2991です。
140回答 すべてを表示
No output devices found
Hello All,
I recently installed a new display assembly on the macbook and had some issues. I finally got the display working when i realized that the audio cable was in backwards pins side up instead of down (dumb mistake). When i put everything back together I was worried that the sound may not work. sure enough its not working. not internal speakers are seen by the computer. the error is no output devices found. I reset the PRAM. and even reinstalled OSX. I have checked all my internal connections to the logic board. i ran a hardware diagnostic and its not seeing any issues. I am worried that the audio board and the cable might be fried... any ideas would be awesome.
PS. plugged in headphones and no go.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
I know this question is old but you most likely tore the audio board flex cable when you disassembled the machine
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Yelitza rodriguez さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 419
