Some of the keys on the keyboard are not working
None of the numbers are working. The FN is not working, neither the Shift key or the Caps Lock. Is this a software issue or a Hardware issue?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi there Ferarnguiz
The problem is hardware issue because the keyboard is malfunctioning to age and usage of the device but there is a possibility that the keyboard settings are different so go to control panel and search keyboard and then click advanced and click at the bottom reset to factory settings . If this does not work consider replacing the keyboard or laptop
If you need more support please email me johnsitservice@outlook.com
このアンサーは役に立ちましたか?
Function keys are not working like brightness,volume etc; after restarting my PC
My Laptop is Lenovo ideapad 330S
The Issue is the Hardware
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 31,232
2 件のコメント
My problem was a software which runs on the background which was filtering keys presses as shortcut inputs.
Try to close all the apps and confirm if the keys works or not.
Steam was the cause for me.
Onur さんによる
No this does not fix the problem.
Mr Keith S Boyd さんによる
