メインコンテンツにスキップ
The fifth-generation Volkswagen Jetta was introduced in January 2005.
30回答 すべてを表示
Tire Pressure light is on, even though the tires are full of air
Out of my manual, the signal is on when i turn the car on, and it stays on meaning there is a malfunction in the system, no message pops up only the low pressure indicator.
Tires are as follow: 36 - 35.5 || 36 - 25
Tire recommended: 34 psi || Front + rear.
*Not sure if having a higher PSI will trigger a warning or not
  • Not sure if the car is checking the pressure in my spare tire or not
  • I DO NOT have a reset button in my glove box, keep in mind i have a 07 VW jetta.
  • i believe the person i bought my car from changed the tires to slightly larger ones, so i don't know if i need more or less PSI
so
*Does my 07 jetta check the spare?
  • is there a reset button some where on the older ( 07 ) models i don't know about?
  • i will lower the psi to the recommended 34 to see if that helps, and check my spare and will update this post afterwards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Does the indicator blink on and off before turning solidly on? If so you might have a fault with the TPMS system.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
VenKazi Productions さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 760
