Screen won’t rotate and microphone stopped working
It happened before I went on vacation so I swapped to my backup phone but broke it on vacation any help is appreciated
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try see if voice memo works, probably it doesn’t either. If you do a search in the iFixit database you’ll see plenty of iPhone 7 users with microphone issues. They are usually due to a fault in the logic board and need a microsoldering Pro to take care of the repair. It’s a routine but challenging repair as on the flip side of the board there are crucial components that may be easily damaged, so choose wisely a reputable shop. Screen not turning is probably caused by a faulty gyroscope..since logic board needs a repair anyway let the tech know of this issue too.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 50
1件のコメント
Has it been dropped or in contact with water? When you make a call, is the speakerphone option greyed out? Also, the lack of rotation could be due to a faulty/broken accelerometer
Cody Auch さんによる
